1969 Shelby Slop Gray floor color
Started by Shelbyguy69, June 01, 2025, 10:08:34 AM
Shelbyguy69
Restoring a 1969 Hertz GT350. Been looking around at the slop gray color layout on he bottom of the Dearborn built cars. Seems to be all over the place as to how it was done. anybody come up with a close version of the paint code?  thanks
There is no paint code.
The term "slop" is referencing primer mixed with left over body color paints.
There is no way to determine the exact color, because it changed on a regular basis. Red Oxide was also used.
If you need information as to where the primer was sprayed, thats a different matter.
Quote from: Coralsnake on June 01, 2025, 10:24:20 AMThere is no paint code.
+1  . To add - the most common range IMO was predominantly gray mixed with a little metallic besides all the other recycled paint usually mixed in. Hard to get this one wrong. If you wanted to get a idea you could get a spray can of slop gray painthttps://www.npdlink.com/product/engine-compartment-paint-under-hood-medium-slop-gray-aerosol/107680 to spray on a paint card as a starting point.
Of course it is the best choice to reproduce a color from a good sample of your cars original finish since the tints and colors can vary. Even had some periods where the firewall rearward was painted a red oxide sealer but that depends on when the car was built at Dearborn as Pete mentioned. Remember that the vast majority, earlier cars verses the a limited number of very late cars, had the surfaces from about the firewall forward coated with the red oxide primer sealer. Smooth and somewhat shinny rather than the flat and open pore stuff some spray
Guess that you have already used the search feature and have seen the article in the thread below
69 Dearborn Undercarriage Finishing - A Guide
I've using a base for the firewall reward section of the 69's using a VW exterior color then tinted bluish or greenish depending on what I want the finished product to look like but as mentioned there
VW Paint Base for Dearborn Undercarriage
M9400ID Volks L17F
   Ful-Cryl Acrylic
430-01   HS Black    822.3
430-03   HS White   1194.9
430-24   Quindo Red   1254.0
430-07   Ochre      1304.0
430-37   Phthalo Blue   1324.3
435-94   Acrylic Binder   3796.6
Well that is at least a starting place Hope it helps
Anyone else feel like after Jeff answers we are all playing checkers while he is playing chess?  ;D
Quote from: TLea on June 02, 2025, 07:35:44 AMAnyone else feel like after Jeff answers we are all playing checkers while he is playing chess?  ;D
Three dimensional chess, "at a level never before seen!"  8)
Quote from: J_Speegle on June 01, 2025, 12:11:13 PMOf course it is the best choice to reproduce a color from a good sample of your cars original finish since the tints and colors can vary. Even had some periods where the firewall rearward was painted a red oxide sealer but that depends on when the car was built at Dearborn as Pete mentioned. Remember that the vast majority, earlier cars verses the a limited number of very late cars, had the surfaces from about the firewall forward coated with the red oxide primer sealer. Smooth and somewhat shinny rather than the flat and open pore stuff some spray
M9400ID Volks L17F
   Ful-Cryl Acrylic
430-07   Ochre      1304.0
You know he is correct
Yes jeff s. answers hold value as when he talks people should listen. We all heard of the million dollar man well jeff is the million picture man. haha
