Rear Brake Self Adjuster Question
Started by SHELB66, April 11, 2023, 05:38:20 PM
SHELB66
I'm finally getting around to doing the rear brakes on my '66 and have a question regarding the rear self adjusters.  The hardware kits come with a washer which I know they should.  The kit I have for the left driver side has a curved spring loaded washer while the kit I have for the right side contains a flat washer.  Is it correct to have 2 different types?  The old adjuster from the left, which is the side I'm working on, has no washer at all!  Any help would be greatly appreciated.
Craig R.
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
02 Explorer Sport Trac
Lincoln tech
Are you talking about the washer that sits under horseshoe clip that attaches parking brake pawl to the brake shoe ?? if so they were always curved.
SHELB66
According to the Ford manual there is a washer on the adjuster itself just behind the removable slotted end cap or "socket".
Craig R.
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
SHELB66
Problem solved!  Found correct "missing" washer in another bag.  Back to work!  Thanks again!
Craig R.
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
Lincoln tech
Quote from: SHELB66 on April 11, 2023, 05:58:39 PM
Craig R.
That one would always be flat
SHELB66
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
