WTB 1968 GT350 4 Speed Thermostat housing and Vacuum Advance
Started by Corey Bowcutt, March 23, 2020, 03:03:30 PM
Corey Bowcutt
I am looking for an original thermostat housing and vacuum advance for my 1968 GT350.  Please let me know what you have.
Thank you,
Corey
Which one do you want? A 4 speed uses the same one as a CJ.
Do you want a correct date coded one?
Follow my advice- ignore Doug. He is not well
A 302 thermostat housing is different from a 428 housing
Quote from: Coralsnake on March 23, 2020, 05:39:26 PM
You mean I got taken again? I want my money back.
Post a picture. I want to see what I've got.
302 has water pump hose connection (ignore arrow)
Top mount vacuum tree
That engine has no distributor. My engine has one. I want a picture of an engine with a distributor!
I'll take a picture of the vacuum advance mechanisms I have later. To me they look the same as the CJ unit.
Agreed on the thermostat housing and tree.
You are correct the vacuum advance is the same
Only on the 4 spd though. The 302 automatic vacuum can is entirely different.
I have two of the 4 speed housings. I think I can cosmetically save them by vapor blasting and then clear coating the steel housing?
I don't know how else to keep it from oxidizing.
I was actually surprised to find that the vacuum advance calibration of the two engines is the same. I didn't expect that.
Incidentally, my vacuum tree has traces of blue overspray on the hex.
4spds are dusl vacuum advance, autos are single pull, the exception is the GT500, those are all single vacuums
Corey Bowcutt
I do not require a correct date code but it is always a plus. My car is Feb 12. But again not a hard requirement.
Rukiddin
We have one vacuum advance here. CORRECT $225 . Looks NOS.
Quote from: Corey Bowcutt on March 23, 2020, 10:22:55 PM
Just to be crystal clear are looking for a thermostat housing and a distributor vacuum advance or thermostat housing and the vacuum switch that goes in the thermostat housing?
Quote from: Coralsnake on March 23, 2020, 06:21:24 PM
Maybe i should rebuild that engine one of these days
