68 GT350 Carburetor Plumbing
Started by Corey Bowcutt, March 19, 2020, 09:15:29 AM
The tilt hose looks correct.
You have the wrong thermostat housing
You should have a vacuum tree.
Your distributor vacuum advance should be a dual style, not the single type
You need to study this page:
http://www.thecoralsnake.com/GT350a
If you can not use the choke tubes because of headers, you can cap those two lines. I have used a vacuum cap on the tube. You can use a brass cap to close off the threaded connection
Once you start changing things ie., headers, it becomes slippery slope
The choke 'chamber' on the exhaust manifold allows carb vacuum to pull hot air up into the thermostatic coil on the carb.  The thermostatic coil is how the choke/butterfly plate on the carb opens and closes.
With headers, it might be best to convert to a manual or electric choke.
Corey Bowcutt
Thank you Pete.  I have been to your site one million times but there are still pages I have not seen and this is one of them.  This answers all the questions but does bring up one more for me.  I have electronic ignition so is the vacuum advance even needed at this point?
If anyone has the correct thermostat housing or vacuum advance let me know.
Thank you so much Pete
Corey Bowcutt
Thank you Charles.  I do have the electric choke off the carb that is on the car now that if worst comes to worst I can use I presume.  But that is why I was thinking about wrapping the metal tube around one of the header tubes so it would continue to draw hot air.  But this was just a wild thought.
Corey Bowcutt
Two more questions occurred to me Pete.
1) does the cast iron thermostat housing with the tree work on the aluminum cobra intake manifold?
2) Do I need to have the hose going to the side of the carb that goes to this thermostat tree?  I currently do not have a fitting in the carb for the hose but I am sure I can get one somewhere.
Corey
Quote from: Corey Bowcutt on March 20, 2020, 11:13:44 AM
Without the vacuum draw, I don't believe the choke will work as designed... or at least be as effective, which will end up causing the carb to run rich.
Chris Thauberger
#22
Posted this on another thread for Milo, thought you might like to have a look.
1968 GT500 Gold Concourse
1973 Cougar
1968 Mustang coupe
1966 Mustang 4 speed vert
1965 Mustang coupe
1968 Cougar
1968 Torino GT
1966 GT350H clone
Troll free at last... I'll drink to that
Chris in your photo the washer spacer goes on the inside of smog pump adjusting bracket bolt unless u have a/c then its not used.
A small block is different and now we are off on a tangent...
The subject car is a 302.
Chris Thauberger
Thanks Ed. I think you or Bob might've mentioned that the first time around. I should explain this picture above and some other ones I posted on another thread were originally posted for all of you to critique before I installed the motor. There are more than likely a few errors in some of the photos.
Pete, sorry my bad I should've noticed that :-\
1973 Cougar
1968 Mustang coupe
1965 Mustang coupe
1968 Cougar
1968 Torino GT
1966 GT350H clone
Quote from: Chris Thauberger on March 20, 2020, 12:19:35 PM
My 302 doesn't look like that? I like all the striped hoses but I must have screwed up?
Krelboyne
Quote from: shelbydoug on March 20, 2020, 01:26:07 PM
No, they slipped in a GT-500 photo.   ::)
Let's get us back on track here...  ;D ;D
Correct '68 GT350 4sp setup...
