Spacer/Filter between Booster and Mater cylinder orientation
Started by Corey Bowcutt, March 21, 2020, 06:11:03 PM
Corey Bowcutt
I got my Booster and MC back from refurbishing and ready to reinstall but I can not remember what orientation the spacer/filter between the two units.  Should the filter be on the top or bottom?  I assume bottom but want to make certain before I install.
Thank you,
Corey
Little side up, filter down.
Quote from: Corey Bowcutt on March 21, 2020, 06:11:03 PM
Thank you,
Corey
Corey Bowcutt
The Going Thing
Corey: Be sure to make sure the rubber inner boot is seated flush with the face of the booster so it doesn't get cut when you tighten up the master cylinder.
