Ammeter at +30... all the time
Started by Grouper Trooper, December 01, 2019, 10:22:59 AM
Grouper Trooper
The Ammeter stays at +30 all the time and I can hear the alternator whining. Same with replacement alt. Car is running fine. Any ideas???
Jayson Horadam
1968 GT 350 #1516
2 X 4 Holley's sittin' on all SCAT 331
www.mpaenforcement.com
Quote from: Grouper Trooper on December 01, 2019, 10:22:59 AM
Have you had the regulator checked?
Grouper Trooper
After seeing your reply, I just replaced it with a new Motorcraft I had in the garage, sadly, no change...  :(
Jayson Horadam
1968 GT 350 #1516
Is it a solid-state or mechanical regulator? I had an issue with two mechanical units. I purchased a Napa solid-state unit, a Concours reproduction cover and ground down the resin until the cover fit. Not an issue since. I was bouncing back and forth from zero to 30 amps.
        -Keith
Grouper Trooper
Both are solid state. The first an Autolite blue top repo and the second a Motorcraft. I just don't know what else could be causing this. This one starts and stays at 30. I can even hear the alternator wine...
Jayson Horadam
1968 GT 350 #1516
How do you have the alternator wires connected under the hood?
Grouper Trooper
using the junction block and diagram on the Branda website and of course the factory plug in.
Jayson Horadam
1968 GT 350 #1516
