WTB Selected Ford 4100 Carb. Parts
Started by Dan Case, November 18, 2019, 07:07:30 PM
Dan Case
Wanted To Buy Ford 4100 Series Carburetor Parts
2 each narrow angle idle mixture needle valve screws
4 each 4 loop coil springs that go with the narrow angle idle mixture screws above  (4 loop springs are rare, most 2100/4100 carburetors use 4½ loop springs)
2 each manual choke fast idle adjustment levers (different part than automatic choke applications) and long fast idle adjustment screws (different part than automatic choke applications)
2 each fast idle cam distance pieces, plated steel version (looks like an odd thick flat washer)
Thanks for looking.
Dan
Dan Case
Dan Case
Dan Case
Dan Case
Dan Case
