1969 428CJ accessory bolts
Started by Sixx7shelby, November 08, 2019, 08:10:33 PM
Sixx7shelby
Need help with the correct bolt type for the power steering bracket attaching to the water pump on a 1969 428 CJ.
67 GT350 #1482
69 Eliminator 428SCJ
97 Cobra
86 SVO
Bigfoot
TTT
Yo Hommie like the size and thread or color n patina deal?
RIP KIWI
RIP KIWI
Sixx7shelby
Quote from: Bigfoot on November 09, 2019, 01:52:48 PM
TTT
Like bolt type.  I have two bolts 9/16 head with built in washer, one is slightly longer than other.  Just wondering if those were right ones Home Slice.
67 GT350 #1482
97 Cobra
86 SVO
Quote from: Sixx7shelby on November 08, 2019, 08:10:33 PM
Flange head bolt .
 There are different different used depending on the exact placement. If it is only holding one bracket directly to the water pump it is the shorter one. If it's holding multiple brackets like in an air-conditioned car it would be the longer one
Several different head markings, common is RBW and also use a lot was one with a F in the center and a third one has no marking in center of bolt however all three are the same type flanged head
There are also differences in the diameter of the flange washer. Ones used to hold an adjustment in slot have a wider built-in washer
427heaven
Quote from: Sixx7shelby on November 09, 2019, 05:49:08 PM
TTT
That's O G gangsta fo sho.
Bigfoot
RIP KIWI
RIP KIWI
Sixx7shelby
Thanks guys, that all I needed to know. I appreciate it!
67 GT350 #1482
97 Cobra
86 SVO
