Fiberglass covers for tractionbars
Started by csheff, October 25, 2019, 10:05:14 PM
csheff
Hi everyone, I've never heard anyone talk about the fiberglass covers that came on the 65 traction bars. What do u know about them or anyone have any pics? What would they be worth roughly?
csheff
SFM5S000
Quote from: csheff on October 25, 2019, 10:05:14 PM
Hello csheff,
I happen to have a set of originals (see photos 1st & 2nd). I also happen to have a set of Branda reproductions (the set on the left 3rd  pic, and the singles side by side the original 4th for comparisons). The repros are not even close. (too skinny and fit horribly. I worked on the repros some, added some material and re-ground them to fit).
Cheers,
~Earl J
Jbarela
Earl...you have everything!! Dont you want to part with them  to me....wink wink..
Shelby_r_b
Quote from: SFM5S000 on October 26, 2019, 05:49:47 PM
Hello csheff,
Cheers,
~Earl J
Great pictures - thanks!
Nothing beats a classic!
mlplunkett
Now, if we only had some good clear photos of the covers installed and photos of the same area with the covers removed we would have everything we needed to fab up a good replication of the original set-up. Anybody with this setup have a camera?
csheff
SFM5S000
#8
Quote from: mlplunkett on October 29, 2019, 01:56:54 PM
Okay Mickey,
I can help you with that. At one point when I was rebuilding/restoring the car, I bought a set of the Branda reproduction pieces. Was I ever disappointed on the fit is an understatement. I only had the rubber flat pieces with a slit at that time until I found a set of original Override covers.
At the end of the day, I decided to forgo the covers and finished the car without either. I was experimenting with special override bars with one end having Heim joints at the time. (I have my reasons). The attached photos are from when I was massaging the repros in trying to make them work. Adding fiberglass and re-grinding them (see photo) The sliver gaps between the covers and the floor after they are riveted down are filled with 3M  Seam sealer (#08505 Beige) is the closest I could find to what was originally used.
If you want I can take dimensions of the originals and send them to you.
Cheers,
~Earl J
mlplunkett
You're the man Earl. By all means send photos and dimensions of the originals. It doesn't look like it would be too difficult to fabricate these. If I get it worked out maybe I could make some extras. I guess the left and right units are just mirror images of each other so once I get the correct profile for the sides of the box the rest should be pretty straightforward.
