1967 GT500 9" Rear End all conditions ok
Started by Kent, September 09, 2019, 01:53:08 PM
Kent
I need a 1967 GT500 rear end 9" I´m interested in everything from concours to restorable....
acman63
just the axle tube or do you need drum to drum with everything?
SAAC Concours Chairman
DC-DD
Germany: How do you plan on shipping?
I have a really nice 67 rear end the type with the large nut fill plug on the back.   Not really interested in crating for such a ride. Do you have a location in the states that you work with?
PM sent with more info
Kent
Shipping no problem as long its on a crate or something, otherwise I have a friend in NC and there are shippers out there that also can bring it to the port without a crate as long its not to dirty.
Drum to Drum would be better
Please with fill plug like it was usual on the GT500
Quote from: Kent on September 10, 2019, 01:07:02 AM
FYI the fill plug was only usual on 67  GT500's built before approximately mid May 1967 at Ford. A later built 67 GT500 typically did not get the fill plug on the housing . That is why the question was posed by Jeff Speegle . If you know which one you need for sure then good ,if you were not aware consider yourself informed. :)
Kent
Oh I only need it for a friend, my GT500 has the one with no plug because it was built end of june 67, my GT500 was one of the very last built cars in LAX
I checked his marti, it was built in may 27 so a housing w/o fill plug should also work? Thats the problem with the mid may cars so many things went different then.
Quote from: Kent on September 10, 2019, 01:36:44 AM
My records and on going survey suggests that big block Mustangs/Shelbys that wee were receiving the rear end housings without the fill plug. Looks like the supply changed back and forth for a while between the two versions but there is a nice tight group near/around your cars finish date
Kent
Ok that makes the search easier, I have seen one GT500 with the fill plug and that one was built also end of may. Do you know when there was a definite end with the fill plug housing?
My car, 3074, has the plug. It's a Ford June car.
Kent
davez
not mine
is this one correct?
https://www.ebay.com/itm/1967-Shelby-9-Rear-End-Housing-Original-67-9-Inch/323910592913
You are bidding on 1 used original Ford 9"  rear end housing. This 9" 1967 Mustang housing with the fill plug in the back was only produced for a short period of time and is correct for 1967 big block cars including 1967 Shelby GT350 , GT500. This was media blasted and primered . This is an original housing and is NOT a reproduction or made from 2 different housings to resemble the original. Overall width 54 1/4 , spring perches are 43" on center
IF YOU ARE RESTORING A 1967 SHELBY, THIS IS THE REAR END YOU ARE LOOKING FOR
The original brake line assembly pictured is NOT included with the auction, but I will include it for FREE if the buy it now price of $1095.00  is used
Black430SCJ
I have one in Ontario Canada. Local pickup $800.00. Needs restoration
Kent
yes this one is working until mid of may, I would need maybe the later style w/o fill plug for my friend.
Quote from: davez on September 10, 2019, 02:03:17 PM
not mine
Kent
As I said before a complete one would be great with all the correct parts.
