drive shaft
Started by kasearch@ix.netcom.com, July 12, 2019, 10:06:42 AM
How do you go about achieving the correct appearance for the drive shaft?  If painting, what color do you use?  69 GT500
67350#1242
Check out Concours Mustang forum article by Jeff Speagle under driveline restoration
http://www.concoursmustang.com/forum/index.php?topic=5723.0
johnzajc@gmail.com
Jack will restore yours to totally original look---he will try to get in on new tube, however insist to keep your original, it will turn out great---Jack is total master in the field
Jack does not have the means to restore or build a 1969/70 GT500 automatic driveshaft. That auto driveshaft is of a special contoured tube design which Jack currently does not have the materials to construct a driveshaft with. He does not have a problem building a 4 speed type driveshaft for a 69/70 GT500 however.
