Cast iron T-10 Transmissions in '66 G.T.350's
Started by 6s1802, July 12, 2019, 12:23:50 AM
6s1802
Anyone know if late 66's had all iron T-10's and if so around what number may have been the transition from aluminum and iron to all iron transmissions.
6s1802
All 1965 G.T.350 transmissions were aluminum. In 1966 San Jose began to run out of the aluminum cases and mixed iron cases with aluminum tail shafts. I verified for my serial number 1802 I should have a iron main case and aluminum tail shaft.
6S1757 is still running the original all cast iron close ratio T-10. Assembly date is C162....March 1st, 1966, 2nd shift.
jk66gt350
I've never seen the assembly date on my T-10.  Where would that be located ?
Brant
Quote from: s2ms on July 16, 2019, 12:12:19 AM
6S1757 is still running the original all cast iron close ratio T-10. Assembly date is C162....March , 1966, 2nd shift.
6S1732 also has it's original all cast iron close ration T-10 with the same date as 6S1757.
-Brant
Brant
Here is the original transmission from 6S933...aluminum main case and cast iron tail housing.
This also shows the location of the assembly date.
-Brant
jk66gt350
Thanks Brant - will have a look for mine the next time I'm under the car.
werthie
hi brant . . . can you please de-code the assembly date stamp?
thanks,
alan
kingchief
Any markings on the cast iron tail assembly?
Steve
SFM 6S406
Brant
Quote from: werthie on July 16, 2019, 03:07:15 PM
thanks,
alan
Alan,
The picture of the transmission that I posted has a assembly date stamping of "A1462"
A   = January
14 = 14th day of that month
6   = 1966
2   = Maybe a shift number (?)
-Brant
Brant
Quote from: kingchief on July 16, 2019, 04:10:14 PM
Steve
Some of them do. In my example from 6S933, the cast iron tail housing is stamped "L 20 65"
L =  December
20 = 20th day of that month
65 =  1965
-Brant
acman63
From my experience they pretty much phased out the aluminum T10s right around the time that they went to under ride traction bars.  Ive seen aluminum in cars on the 1000s serial wise  and Ive seen all cast iron as low as in the 1200s. Ive never seen any factory minutes or paperwork showing they mixed and matched alloy with cast iron in the production cars but Ive seen ads for the transmissions that way .  the tailshafts were very fragile and they broke easily
SAAC Concours Chairman
Greg
Quote from: acman63 on July 16, 2019, 06:02:16 PM
6S1078 has an all aluminum T10 maybe this was at the switch over point.
Shelby's and Fords from Day 1
jk66gt350
Curiosity got the better of me so I had to have a look.  6S1575 is mid March Ford production date, T-10 main housing date is C 162 or March 1, 66 and tail housing is K 15 65 or November 15, 65.  Both cast iron.
