1965-1966 K Code Rearend Complete Drum to Drum
Started by mtdubvee, March 30, 2019, 03:31:48 PM
mtdubvee
Selling an original K code 9" rearend. It's complete drum to drum.
Center section is dated 7B23 so I assume that's obviosuly been changed.
Not sure of the gear ratio. Housing is very nice. Has the brake line bracket.
Has the correct pinion snubber bracket for a 66.
Very nice original piece.
52" backing plate to backing plate. Spring perches 44" center to center.
$1850.00 or best offer. Will pallet and ship. Buyer pays for shipping.
Located in Beckley WV 25801.
Call or email for pictures.
304–228–4732
Mtdubvee@yahoo.com
SFM 5S123
SFM 5S269
1967 GT350 #41 Raven Black 4 Speed
Quote from: mtdubvee on March 30, 2019, 03:31:48 PM
Has the correct pinion snubber bracket.
$1850.00. Will pallet and ship. Buyer pays for shipping.
304–228–4732
Mtdubvee@yahoo.com
Which pinion snubber bracket is it?  The 65 or the 66 . They are different.
corbins
Quote from: corbins on March 30, 2019, 07:42:43 PM
Good question Bob ...
If you are not sure how to tell then a picture front facing of the shield will show the difference.
mtdubvee
I posted a picture above in the original
Post.
SFM 5S123
SFM 5S269
Thank you. FYI that is the 66 style snubber bracket.
mtdubvee
SFM 5S123
SFM 5S269
Greg
Looks like a 65 and carryover.  I believe the 66 had a the big drain plug.
Shelby's and Fords from Day 1
Quote from: Greg on March 31, 2019, 08:56:59 AM
The center section is from a 67 and the snubber bracket is from a 66.
SFM6S087
Agreed. Also, the cover on the back of the center section looks dome shaped - indicating a 1965 housing. The 66 is more of a half dome. Although I don't know if there might be some overlap between the years on that feature.
Steve
Greg
Quote from: Bob Gaines on March 31, 2019, 05:14:32 PM
Bob, Thanks for the education.  I knew it wasn't a 66 but how did you know it was for a 67?  Always learning :-)
Quote from: Greg on April 01, 2019, 07:26:41 PM
No special expertise just simply read the OP's post where he stated it had a 7B23 dated center section. That decodes as Feb 23 1967.
Greg
Quote from: Bob Gaines on April 01, 2019, 09:43:35 PM
Thanks Bob, I knew the center section was, I thought there was a difference in the axle housing with 66 being the large drain plug and hump and the 65's rounded back with small drain plug.  I thought you were pointing out that the housing was a 67 and wondering what the difference was.
Quote from: Greg on April 02, 2019, 10:32:57 AM
Nope , I said center section and meant center section just like the OP. I was explaining the combination of parts.
Duncan66
