1967 GE/FOMOCO low/high beam headlight
Started by nightmist67, March 24, 2019, 10:12:31 AM
nightmist67
Wanted:  One (1) 1967 GE/FOMOCO assembly line low/high beam headlight for Shelby Mustang, fully functional, lens intact with no chips or cracks, no discoloration of bulb reflector backing, electrical contacts intact and not corroded.
Dizzy
Is the FoMoCo logo etched into glass or molded?
acman63
SAAC Concours Chairman
Quote from: Dizzy on March 30, 2019, 04:07:42 PM
As Jim said etched. Westinghouse was the one that had the trademark molded . Westinghouse was not typically used at SJ for 67's . I haven't seen Westinghouse on 68's or 69/70 Shelby's ether. If they were used in 68 or 69/70 Shelby it certainly would be in the minority.
greekz
What is the number of the Low/High beam?  I have a spare bulb, 4001.
SFM 6S1134
'67 GT-350 #2339
'65 Fairlane Station Wagon
2002 T-Bird (since new)
'25 Explorer ST
texas swede
As far as I know, 4001 is the high beam only, i.e. middle lamps. 4002 are the ones with low beam and high beam,
i.e. outside lamps.
Texas Swede
greekz
Quote from: texas swede on March 31, 2019, 06:20:22 AM
i.e. outside lamps.
Texas Swede
Thanks for the clarification.
Greek
SFM 6S1134
'67 GT-350 #2339
'25 Explorer ST
acman63
He needs a 3 prong GE Bulb  with Fomoco etched  that works on hi and lo beam
The 3 prong are harder to find in working condition because they were used every time the headlight switch was pulled . By contrast the 2 prong was only used when the high beams were used.
Best place to find them in years past were postal and some other delivery vehicles since they rarely needed to use their headlights ;)
Dizzy
#10
My experience has been after tracking down and buying any of the original or NOS SEALED BEAMS that first test resulted in almost immediate burning out of filament,resulting in the glorious grey smoke that also ends up on the reflector...."No returns on electrical parts"
My "collector" sealed beams are never,ever exposed to 12 volts. Deduct all you want,but I will not destroy a perfect bulb to answer an obvious question. Ever smoked one?    ;D  It hurts.
