1968 Shelby trunk mat
Started by Corey Bowcutt, February 25, 2019, 08:25:05 AM
Corey Bowcutt
I purchased from NPD a "correct" speckled burtex trunk mat for my 1968 GT350.  I tried installing it and there are fit issues.  Where the mat meets the taillight panel it appears too long.  Do folks trim this or just let it roll up as shown in the picture.  There is also a tricky corner that bunches a bit in the upper left corner when looking into the trunk where the mat makes the transition from the lower fuel tank floor to the upper trunk sheet metal.  Do folks do some trimming here or just let it bunch?
Thank you, Corey
Quote from: Corey Bowcutt on February 25, 2019, 08:25:05 AM
Thank you, Corey
Just like with a restored car where the workmanship is typically better then the factory the things you described could vary from mat to mat to some degree. There are better fitting mats and worse fitting mats.The factory did not however do any extra trimming . With that said if you can change the look without leaving evidence that trimming was done then it shouldn't be a problem. In concours judging for instance you have to consider the range and only deduct for something that is way outside the normal.I hope this was helpful.
That's not the correct mat.  Is that one black on the backside?
Corey Bowcutt
Yes it is. Would love to know why? It was sure advertised as being correct in the NPD catalog.
ACC makes the correct one that actually is OE material and contours. I posted a picture of my trunk finished. It's made of burtex, like the originals.  It's been in the last few days.
        -Keith
Corey Bowcutt
Hmmm, I guess I really have no idea what burtex is but this was advertised as burtex as well. So much I do not know.
If it is black on the bottom, it's not correct.
Corey Bowcutt
What color should the bottom be?
I borrowed this from another post. This is what the Burtex looks like on the back.
                                                               -Keith
Quote from: 1967 eight barrel on February 25, 2019, 09:58:54 PM
Keith, some early 68's used the plaid mat like 67 but most later Metuchen cars used a speckled mat like the OP posted. The speckled mat is not Burtex originally. It is a multi colored fiber on the back side . At least the originals are. I am not sure about the good repros.
I have a plaid mat. I didn't remember when they went to the speckled pattern. However, they are still molded mats.
Quote from: 1967 eight barrel on February 26, 2019, 02:35:56 AM
There is also that dark felt looking version also.   68 was an interesting year. Know we posted pictures of each, just can't recall if its been reposted since the forum dump
I have not seen the plaid 1968 NJ mats. But, if Mr Gaines says he has, I believe him.
Burtex tends to look like a very thick felt on the backside. The colors vary. The reproduction mats are more of a pressed straw, light brown, look to me. The originals were molded. One of the problems with cutting the mats is every car is a little different. I have a few originals (of each bodystyle) that I use for reference.
I am not sure what the reproduction mats use for a pattern.
Corey Bowcutt
I spoke with NPD and they in fact sent me the wrong mat.  They sent me a vinyl one where I ordered a Burtex one.  I had no idea what Burtex was so when it arrived I did not know it was incorrect.  So I am returning it and going to buy directly from ACC because they have one listed specifically for 1968 GT350 so I feel better about that.  The Burtex ones sold by NPD actually do come from ACC but NPD does not list the one specifically for the 1968 GT350 like the ACC web site does.
I do love this forum for all the help it gives me!!!!!!!!!
Corey will be soon entering his car in concours  ;D
