67/68 GT500 Original AC Oil Cooler, Adapter & fittings
Started by 68stangcjfb, February 23, 2019, 12:30:44 AM
68stangcjfb
Parts came out of a 68. Original paint on cooler. Fins very straight. Absolutely does not leak. Setup was on a running engine 3 months ago. I have lines I will include but they are not correct. $1400.00
68stangcjfb
67GT500#1594
Can you post a pic with the legnth of the oil cooler please? Thickness as well.  I need to see if this fits my application better than what I had collected. Thanks!!
68stangcjfb
The dimensions minus the fittings are 15" long, 3" thick & 4" wide. 6" wide when you include the hanger brackets.
Quote from: 67GT500#1594 on February 23, 2019, 07:38:39 PM
From a function stand point you can do better. From a originality stand point you can not. FYI the 67 cooler although the same were painted black instead of the teal blue.
Quote from: Bob Gaines on February 24, 2019, 02:22:40 AM
Well heck, if you put in an all aluminum 500 cube big block, it's going to melt anyway.
68stangcjfb
Mike James
Anyone have a pic of how the lines go through the radiator support?  Were holes drilled for the lines?
68stangcjfb
Quote from: Bob Gaines on May 08, 2019, 12:30:01 AM
Quote from: shelbydoug on May 07, 2019, 09:00:49 PM
That's a heck of a grommet.
It is not a grommet but a section of windlace.
Yes, I realized that right off. I was being creatively critical.
Now that couldn't have been Ford installed so it must have a Shelby part number on it? (there I go being creatively critical again)  8)
