KR Dzus spring installation
Started by GT350AUS, February 19, 2019, 05:30:19 AM
GT350AUS
Quick question regarding the Dzus spring installation on the locking bracket of the KR Hood Pins.
One of my Dzus springs is loose making the lock down difficult. What is the correct finish on the rivet and what type of rivet is correct?
Pictures will help thanks
The rivet is natural aluminum.  It is a solid head type rivet.
68blk500c
Interesting.  The three sets I have drilled out were steel, not aluminum.
68blk500c
Of course you can.
I read the question as referring to the rivets holding the wire to the L bracket on the radiator support.  However, if the question is about the hood twist plates/discs, then those rivets are aluminum.
GT350AUS
yes the question is regarding the rivets holding the wire.
Thanks  ;)
