Heater fan operation
Started by Corey Bowcutt, February 10, 2019, 05:04:57 PM
Corey Bowcutt
The heater fan is the last electrical thing in my car I need to fix.  It has not worked since I purchased the car.  I tested the motor by applying 12 volts directly to it and the fan motor worked just fine.  So I am assuming the switch is bad.  My question is, is there anything else in the chain that could be faulty other than the fan switch?
Thank you, Corey
Dizzy
There is a resistor pack that gets used for different fan speeds. Best to get a wiring diagram and study it.
Chris Thauberger
1968 GT500 Division II Gold Concourse
1973 Cougar
1968 Mustang coupe
1966 Mustang 4 speed vert
1965 Mustang coupe
1968 Cougar
1968 Torino GT
1966 GT350H clone
Troll free at last... I'll drink to that
It's likely the resistor. They take five minutes to change and run about 12.00. The wire coils from heating and cooling cycles get brittle and break off.
Here is the link to the part. If you don't know how to get the push pins off to change it, shoot me a PM. I'll walk you through.
        -Keith
https://www.npdlink.com/product/resistor-heater-switch-exact-original-style-replacement-to/103117?backurl=search%2Fproducts%3Fsearch_terms%3Dblower%252Bmotor%252Bresistor%26top_parent%3D200001%26year%3D1967&year=1967
I'm not sure about 67-68, but the 65-66 style heater switch that has the 2 wire motor and resistor on the front of the box requires a good ground of the bezel to the dash.  Might check that to rule out since the motor works when wiring direct.  Should be able to test current at the resistor and switch with a test light.
Corey Bowcutt
Over the weekend I disconnected the cables from this heater resistor and found one of the pins was broken completely off so this is most likely my problem.  I have ordered a new resistor assembly but need to know how to remove those two white plastic "rivets".  Any suggestions?
Thank you,
Corey
Next stop,  concours at Pebble Beach  8)
You need to push the white center pin out. It requires having the front cover off the box.
You could probably drill them out , but you need to be very careful not to pierce the core
 Two things you can try. One is if you take a small screwdriver under the head generally you can work them loose. The other thing is as Pete said just to do you could always drill the pins out and replace them. I think West Coast cougars carries replacement
Corey Bowcutt
Thank you Tim and Pete.  Is the cover easy to remove?  I will try the screw driver wiggle thing but if the cover is easy to remove without tearing apart a bunch of other stuff I will do that.
 It's easy to remove if it's out of the car. If the heater box is installed in the car I would think it would be incredibly difficult
KR Convertible
I would think the easiest way is to grind off the heads of the plastic rivets and replace them.  Otherwise, cut the old resistor center out to access the back of the rivets with a "L" shaped pick.
Corey Bowcutt
