thermostat housing
Started by 65Clone, January 08, 2019, 07:23:44 PM
65Clone
On the 65 Shelby did they reuse the cast iron thermostat housing on the aluminum intake or something else?? C40E????
acman63
C5  other than  the very first cars
SAAC Concours Chairman
Both types of t-stat housings (recessed/non-recessed) were die-cast, not iron.
Quote from: CharlesTurner on January 08, 2019, 10:07:37 PM
To add, many times after market thermostat non factory versions are cast iron.
#4
Hi all,
IIRC, the small letter COBRA intake has a recess for the thermostat.   So I would think functionally the non-recess thermostat housing would be best, even if both were used.  I would recommend the flush (non-recess) housing.
Also, if you are really serious, these things are date coded, so it will need to be dated prior to engine assembly date.
