66 350 Grille
Started by tblackgt350, December 14, 2018, 06:49:29 PM
tblackgt350
 While the motor is out of the car I want to get the grille cleaned up; I vaguely remember reading somewhere that the way to do this is to remove the grille, scrub it with steel wool, repaint the bars satin black then go over the front of the grille again with steel wool to remove paint from the chrome. Does this sound right? Things look to be good except for the chipping black paint.
Also, is the monte carlo bar supposed to be gloss black?
It seems that every time I look at the car now I seem some other thing that I want to make better.
Rocket
That's the way I did my grille on 550. Ron
kram350
I like to tape off the highlighted areas. Mask and then use a razor blade and cut the tape along the fins. Saves a lot of elbow grease trying to get the paint off those thin fins. The masking goes pretty quick once you get the hang of it.
Quote from: tblackgt350 on December 14, 2018, 06:49:29 PM
Monte Carlo bar was typically painted a semi gloss black.
