WTB: 1967 Shelby Parts....
Started by FordGT, December 09, 2018, 07:18:13 PM
FordGT
Looking for the following 67' parts....
- Passenger side hood pin mounting bracket
-  Aluminum Tail Light Trim Ring, early style with screw in studs
- Tail Light Inner steel mounting brackets
- NOS fiberglass quarter panel end caps
Also looking for 1- C7ZE 289 HiPo head in good shape, non-smog..
Thanks, please send me PM....
7777kx
I have a pair of original tail-light inner steel mounting brackets from a 67500. Blast cleaned and satin-black powder coated, so ready to go.
please email me at faulknerstevens@btinternet.com if you would like some pictures.
Thanks Alan
Quote from: FordGT on December 09, 2018, 07:18:13 PM
The correct for your car "tail light inner steel mounting brackets " are determined most successfully by your car's completion date at SA , Shelby VIN and the current style of fiberglass tail panel you have . There are different types that were used originally depending on when the car was built at SA.
Quote from: Bob Gaines on January 30, 2019, 09:49:13 PM
As stated, both cars should be/have "flat" or "raised" Shelby fiberglass tail light panels, as the inner Shelby brackets are different depths.
What are the Shelby completion dates, or is it known for certain if the cars had which panel from new?
