Tach not working
Started by PR, October 15, 2018, 02:00:55 PM
PR
Car runs fine but tach not working, any ideas, it would not run if circuit not complete , I am thinking it's the tach itself, thanks
just had the same problem cross jump the tach wire plug in & see what happens.
PR
no do this before u start car & see if it runs then u know bad tach or not
PR
Found problem, someone by passed tach, when reconnected car will not run, tach bad, now I know where to start
cj750
FWIW, I highly recommend Rocketman's tach conversions. I've been running one for several years now. Works great, looks 100% stock, and if it should ever fail, it won't affect the ignition. https://www.rccinnovations.com/index.php?show=menu-mustang-all
Every post I make comes with an implied request for corrections. I'm here to learn.
PR
Thanks for the tip on Rocket man
Quote from: PR on October 16, 2018, 11:16:35 AM
I would stay away from the rocket man if you want to keep the tach as Ford built the car. Rocketman does not have the Ford parts to fix your tach, he converts them to a three wire movement. Fine if that's what you want. Phil Severence is the way to go. He worked for Ford, knows the tachs, they are repaired with Ford parts and they work when they come back, unlike the Tachman.
Phil does it right, in a couple weeks and stands behind his work.
www.PhidonRestorations.com or email me at psev@cableone.net             -Keith
Quote from: 1967 eight barrel on October 16, 2018, 09:08:01 PM
Kieth,are you saying that rocketman is the same as tachman?
Bob, Negative. He just does the three wire conversions. We spoke, and his parts supply to repair original tachs are very limited. You know my story with Tachboy.  I suggested having it repaired so it operates without additional wiring. The conversions are three wire.
        -Keith
pmustang
Phil has done a fair amount of work for me, Very happy.
Mopar dash, 2 Tach dashes.
