1967 Anti-Wrap-Up Snubber Brackets
Started by bbeardmore, September 22, 2026, 01:24:38 PM
bbeardmore
Does anyone happen to have a single 1 or a set of S7MS-4095-A snubber brackets for sale or "for measurements!" I'm  trying to find a single or a set to buy to reproduce an accurate copy. Or if you have a set you could provide some measurements... that would be gold too. I've got a starter model that I print on my 3D printer but the end part will be foundry cast aluminum or cast iron, maybe nodular (if my pot can get that hot)
I've attached a graphic of the measurements I'm looking for. Please help if you can. Email is bbeardmore@carvizor.com
Yes a much needed part. Cast iron would be best but aluminum would be a cheaper second best alternative IMO.
Shawn
I had 10 sets made about 20 years ago.  They were perfect in every way.  Sold them to Shelby Parts maybe try them if they have any left
Shawn
NPD sells them without the engineering numbers and holes drilled in the side for some reason.
Quote from: Shawn on September 22, 2026, 04:21:21 PMNPD sells them without the engineering numbers and holes drilled in the side for some reason.
NPD doesn't have them have them and don't know when or if they will have them again.
