1967 GT350 fuel pump rebuild info
Started by SunnysideTom, August 15, 2026, 11:11:45 AM
SunnysideTom
Thanks for reply , my fuel pump has 6 screws that hold the pump top to base so apparently not original . Now to find out whose pump this is , some have mentioned Carter High Performance but thanks .
Quote from: SunnysideTom on August 15, 2026, 11:11:45 AMThanks for reply , my fuel pump has 6 screws that hold the pump top to base so apparently not original . Now to find out whose pump this is , some have mentioned Carter High Performance but thanks .
I figured as much. If it is in fact a Carter there is typically a Carter trademark on it somewhere. If it is a Carter then there is a nominal priced rebuild kit readily available.
