BF 32 Autolite
Started by SCOTTGTK, May 27, 2026, 09:15:22 PM
SCOTTGTK
Good evening, anyone running a set of original Autolite BF 32's in their K code?
Thanks, Scott
65 K code coupe 5F07K338XXX
trotrof1
That's what I use in my 66 350. No issues, Nice uniform light tan color.
GT350Lad
Yeah 2 GT350s with them in, no worries
5S274
6S373
6S1276
greekz
I am running them as well in both GT-350's.  No issues over the last 35 plus years.
SFM 6S1134
'67 GT-350 #2339
'65 Fairlane Station Wagon
2002 T-Bird (since new)
'25 Explorer ST
SCOTTGTK
Thank you all for the responses... can I ask where you've been able to find them? I have seen a set or 2 on Ebay here and there?   Scott
SCOTTGTK
Also, does anyone here run Pertronix as well? I was wondering if that's an issue running BF32 plugs with Pertronix. Last question, I do see a few sets for sale on Ebay as I mentioned and a wide range of prices... what's a fair price for 8 or 10 plugs?  I see $1400 to $135?
Thank you all, Scott
Quote from: SCOTTGTK on May 28, 2026, 02:36:55 PMAlso, does anyone here run Pertronix as well? I was wondering if that's an issue running BF32 plugs with Pertronix. Last question, I do see a few sets for sale on Ebay as I mentioned and a wide range of prices... what's a fair price for 8 or 10 plugs?  I see $1400 to $135?
The high prices are typically for the BF32 star marked plugs.  Autolite marked BF32 are about 10.00 or more each .The BF32 Motorcraft marked plugs are less but I don't keep track of those.
trotrof1
I am using the Pertronix with 32s and OEM coil. Works OK in my cars.
SCOTTGTK
Thanks Bob, trotrof1, any thoughts on differences between Autolite and Motorcraft?
Bob, I've seen star marked plugs, any difference in performance or were they star marked due to being older or newer?
A-Snake
BF42 might be a good option. A little hotter plug.
Quote from: SCOTTGTK on May 28, 2026, 06:07:25 PMThanks Bob, trotrof1, any thoughts on differences between Autolite and Motorcraft?
All BF32 are the same heat range just different in appearance. If you start to foul plugs or the tips don't look lean enough when you inspect them you can go to the next step up to BF42 as A-Snake/Jim suggested. A lot of us have done that over the years when we street drove the cars more.
TA Coupe
I have a bunch of autolite BF 22 spark plugs. Does anyone use those anymore? Any particular engine use them?
      Roy
If it starts it's streetable.
Overkill is just enough.
Quote from: TA Coupe on May 28, 2026, 10:52:33 PMI have a bunch of autolite BF 22 spark plugs. Does anyone use those anymore? Any particular engine use them?
Roy
BF22's were heat range #3 IIRC, one range colder than BF32. Pretty much a racing only plug, don't believe it came factory in any production car.
Another option if you want to use BF32's is the Autolite #34 plug. After Ford and Autolite separated in 1972, all Autolite plugs got the Motorcraft name, Autolite continued making plugs with a new numbering system. The BF32 was now Motorcraft while the Autolite version was #34, same exact plug. You can find Autolite 34's cheaper than BF32's, here's a set on ebay now:
https://www.ebay.com/itm/127812391980
