Removing hood springs
Started by 6S896, September 30, 2018, 08:38:06 PM
6S896
Hey guys if you have an original hood that isn't warped would you suggest pulling the springs from the hinges and installing a prop rod to keep this from ever happening? Just seeing your thoughts thanks.
Quote from: jgroce1985 on September 30, 2018, 08:38:06 PM
If you feel paranoid about the hood warp thing you could always unhook the springs and carry around a wooden prop rod or equivalent to use to keep the hood open. You could reconnect the springs for show and tell.  I had a 69 that the springs would flex the hood enough when it was shut that I only connected them when I had to leave the hood open. I have others that don't have the flex.  I got real quick disconnecting and re connecting springs every time I opened my hood and didn't use a prop rod. I could do both springs in about a minute and half.  A tire J hook became my go to tool when I did the disconnect re connect . I would definitely suggest not to "install" a prop rod. Carry one if you need to when leaving the hood open but do not do any kind of permanent installation is my advice.
I've kept,used a short section (may be 4-6" long) of vinyl coated chain. Slip a screw driver in one end link and slip the other over the other end and pull a little.  After a while the vinyl will tear through on that end so you just cut the last link off and use the next one.  Maybe a little shade tree but a quick, easy to store tool when you need it ;)
papa scoops
both good ideas, but the slip factor and risk of chipping the paint. be careful. phred
I have seen a used belt used to pull the spring on.
Darrpo
I have used a fan belt for years. If you never tried one, give it a try and you will never use anything else to remove or connect the hood springs
6S896
Thanks for all the suggestions guys. I'm thinking I will go ahead and remove them. I know on my 69 Hertz car the hood was in real bad shape and I would hate to run into that issue again.
