1969 GT350 tail light wire harness and cover panels
Started by Leterip, January 25, 2026, 05:45:56 PM
Leterip
Trying to figure out how the factory fed the rear brake and turn signal wire harness along the rear of the car.  I have these fiber board panels that cover the wires but the shelby lamps stick out kind of far and appear to interfere with the panels. 2 questions-
1.-did the factory cut holes in the cover board so that the back of the light sockets would protrude out beyond the cover board
2.  Was the harness anchored outside of the ground screws to keep it from moving around while the vehicle was in motion?
Quote from: Leterip on January 25, 2026, 05:45:56 PMTrying to figure out how the factory fed the rear brake and turn signal wire harness along the rear of the car.  I have these fiber board panels that cover the wires but the shelby lamps stick out kind of far and appear to interfere with the panels. 2 questions-
The original cardboard panels are "rolled" . The middle sticks out farther then ether end.  You have to make them that way on repro panels.   The end by the filler neck is held with a screw and the outside end is held by a washer nut "flange style". The nut goes on a stud that fits in a slot . The washer nut and stud are on a regular Mustang in that area.
Shelbypat
Patrick
Canada
There are some taillight board pictures on the dead nuts on website that may help you understand how they are supposed to look and yes they were grey from the factory. https://www.deadnutson.com/shelby-taillight-panel-board-hardware-kit/
