Vacuum lines under hood- GT500
Started by jimhyc, December 17, 2025, 11:09:53 AM
jimhyc
Need a little help on the vacuum lines to the canisters under the battery and hood hinge. For some reason a previous owner removed all the vacuum lines. The 428 has tilt and air. I have the diagrams but they don't seem to make sense. There is one vacuum port on the can under the battery tray and two on the can under the hood hinge (large and small ports)
1969 GT500
2005 Saleen S281
1973 MACH1 Q code
1967 Mustang
1965 Galaxie 500
1969 Thunderbird
1988 Turbo Coupe
1928 Pierce Arrow
1930 Pierce Arrow
Prior cars
1967 GT500
1970 GT500
1968 KR
1970 BOSS 429
Daytona Coupe, 427 Cobra - kits
1971 BOSS 351
Single (tilt) goes to one way tee near firewall. Pull side of the tee (single) goes to brass block on rear of intake. Last port off tee goes to tilt solenoid under dash. AC large nipple  goes to brass block, small nipple goes through firewall to Heater control
jimhyc
Quote from: TLea on December 18, 2025, 03:51:10 PMSingle (tilt) goes to one way tee near firewall. Pull side of the tee (single) goes to brass block on rear of intake. Last port off tee goes to tilt solenoid under dash. AC large nipple  goes to brass block, small nipple goes through firewall to Heater control
Thanks.. which vacuum line goes to the can under the battery tray?
1969 GT500
2005 Saleen S281
1973 MACH1 Q code
1967 Mustang
1965 Galaxie 500
1969 Thunderbird
1988 Turbo Coupe
1928 Pierce Arrow
1930 Pierce Arrow
Prior cars
1967 GT500
1970 GT500
1968 KR
1970 BOSS 429
1971 BOSS 351
Quote from: jimhyc on December 18, 2025, 05:03:12 PM
