Transmission Inspection Cover For '67 With A 289 4 Speed Wanted
Started by Fast Fords, December 02, 2025, 10:03:05 AM
Fast Fords
Looking for a transmission inspection cover for 67 Mustang with a 289 hipo 4 speed car. Email gandcmurphy@rogers.com if you can help. Thanks for any help.
Small blocks with manuals had a one piece (not separate inspection plate or hole) engine plate that separated the engine and transmission bell housing. Is that what you are searching for?
Quote from: J_Speegle on December 02, 2025, 02:39:45 PMSmall blocks with manuals had a one piece (not separate inspection plate or hole) engine plate that separated the engine and transmission bell housing. Is that what you are searching for?
He might be confusing it with the automatic inspection cover that bolts to the different automatic block plate .
Road Reptile
Hi folks,
Maybe you are looking for the top cover for a top loader transmission??
If so David Kee makes a nice reproduction. Inspection cover makes most of us think of the flywheel cover that is used on an FE equipped 4 speed.Hope this helps.
R.R.
Fast Fords
I am not exactly sure what I am looking for. I have a 67 Mustang with a K code 4 speed tranny. Do I need an inspection plate cover or do I need the large plate that separates the transmission and the motor? Any help is appreciated. Thanks.
Quote from: Fast Fords on December 02, 2025, 04:41:25 PMI am not exactly sure what I am looking for. I have a 67 Mustang with a K code 4 speed tranny. Do I need an inspection plate cover or do I need the large plate that separates the transmission and the motor? Any help is appreciated. Thanks.
For the 67 K code 4 speed you need the block plate that goes between the bell housing and the block. Other then the hole for the crank and starter it is a solid plate.
Quote from: Fast Fords on December 02, 2025, 10:03:05 AMLooking for a transmission inspection cover for 67 Mustang with a 289 hipo 4 speed car. Email gandcmurphy@rogers.com if you can help. Thanks for any help.
Contact Dan William's in the Carolinas
Haven't spoke to him in a few years, but he had everything and anything to do with top loaders.  Also anything F O R D
attached is his phone number from our contacts
Best of luck on your endeavors!
Fast Fords
Thanks for the info guys and thanks for the picture Jeff. I will try to call him tomorrow FL SAAC and see if he might be able to help me out. Thanks again.
Quote from: Fast Fords on December 02, 2025, 09:20:04 PMThanks for the info guys and thanks for the picture Jeff. I will try to call him tomorrow FL SAAC and see if he might be able to help me out. Thanks again.
Danny is "not" a morning person call him tonight or tomorrow any time after 3 or 4 p.m.
Best of luck
