Radiator tie rod to side straps
Started by 6s1640, November 03, 2025, 10:18:13 PM
Hi all, does anyone know if there is a source for either 20 or 24 inch radiators side strap tie rod?  This is the small diameter rod that runs mid high on radiator that hold side straps from flexing out.  The attached image are a loose rod from a 68 small block radiator and on the radiator.
Quote from: 6s1640 on November 03, 2025, 10:18:13 PMHi all, does anyone know if there is a source for either 20 or 24 inch radiators side strap tie rod?  This is the small diameter rod that runs mid high on radiator that hold side straps from flexing out.  The attached image are a loose rod from a 68 small block radiator and on the radiator.
They are relatively easy to make . I would concentrate on that angle to obtain one.
Hi Bob,
Thanks for replying. I was thinking that was probably going to be the case. Catch you later.
Hi Bob,
I did it. It took a little developmental work and a hint from my neighbor who was in the fabrication business, but I think I'm pretty close to replicating an original tie rod. See attached image.  Mine is on the left and the original is on the right in both images.
Well done. Thats how the vendors start!
Quote from: 6s1640 on November 05, 2025, 04:18:37 PMHi Bob,
Excellent job. I well take 2. ;D  ;D
now find the thin cutter nuts anybody find a source for them?
just viewed your results, great research and development on your part !
#8
Hi Special Ed,
I already did find the cutter nuts, from a company called Skycraft Parts and Surplus out of Orlando Florida.The nut has also been referred to as pal nut, speed nut or stamp steel lock nut. I had to buy 100 of them., So I will have extras.
I will buy someof your  extras hope they are the correct size.
