WTB. 1967 San Jose Big Block Radiator
Started by FordGT, October 14, 2025, 11:02:56 PM
FordGT
Looking for late Big Block 1966 San Jose radiator, November, December or maybe January of 1967.
Cars built date is Valentines Day.
Please send me PM, Thanks
Mike_Senar
Hello from San Diego,
  I have several "warranty" or "dealer service replacement" radiator cores.   All are WMO if I remember correctly.   These have NO part # stamped on the outer straps!   If interested contact me privately with a cell # and the top tube and bottom tube configurations and I will send some pictures of what I have.     These were all pulled from wrecked Mustangs 25+ years ago and stored in my shed from the weather...
                                                         Mike
Quote from: Mike_Senar on October 15, 2025, 10:56:52 AMHello from San Diego,
                                                         Mike
Mike for you and potential buyer, only the Dearborn or Metuchen radiators had a engineering number stamped on the outer strap. The SJ radiators did not have a number stamped on the outer strap. The SJ radiators had the the WMO and the date code embossed on the upper tank which is hidden when the top radiator support is attached. The SJ radiator had it's engineering number stamped on a steel tag that was soldered on where the side strap is soldered on typically on the driver side. If a SJ tag is missing a exact reproduction tag is readily available from AMK.
Mike_Senar
Well, Well, Well...
  I was not aware of this feature.   Maybe these radiators are originals then.   I have been thinking otherwise all these years.   Thanks for the info.
                                                Mike
I have one with tag i think is an auto if u need it
mtdubvee
I have a 1-67 Big Block WMO radiator for a 4 speed that's in great shape.
Call me at 304-228-4732
Matt
SFM 5S123
SFM 5S269
1967 GT350 #41 Raven Black 4 Speed
Quote from: Bob Gaines on October 15, 2025, 12:56:25 PM
                                                         Mike
and you can buy the amk tag right here to complete your radiator
best of luck on your endeavors
Ford Radiator Tags — AMK Products, Inc.
https://www.amkproducts.com/parts/ford/radiator-tags/
