65 66 289 Hipo Carb For Sale
Started by Fast Fords, September 26, 2025, 03:40:36 PM
Fast Fords
I have a used 289 hipo carb for sale. The numbers on the tag are C6ZF C with A 5HD below that. The carb is in good condition as everything moves freely. This carb is for a stick shift car. It will need to be rebuilt though. The numbers stamped on the toe are 6Z C. Price on this carb is $2000 plus shipping. If interested, email gandcmurphy@rogers.com Thanks.
Cobra66
Hello, Interested in purchasing the carb from you. Can you please confirm if the primary booster has an M stamped on it?
Also please advise where you are located.
TA Coupe
Enhanced the carburetor tag a little bit for you.
     Roy
If it starts it's streetable.
Overkill is just enough.
SCOTTGTK
Roy, can you provide a clear pic of the venturi stamp, it seems to be blocked partially by linkage. Also interested in the primary booster question. Thanks Scott
65 K code coupe 5F07K338XXX
TA Coupe
Not my carburetor.  I just enhanced the picture that he put posted.
     Roy
Fast Fords
Fast Fords
Here is a picture of the primary booster.
SCOTTGTK
Fast Fords
#8
Carb is sold. Thanks.
