NOS MUSTANG pin letter sets
Started by 21.04, September 21, 2025, 09:49:42 PM
I'm listing an NOS pair MUSTANG pin letter sets.  Sorry, there are no Ford boxes or FoMoCo envelopes.  Reproduction letters are filled in on the backsides.  You can see there are hollow pockets on all the letters on these ones.  These also come with all the grommets.  $850 plus shipping for a pair or $425 for just one set.
Matt
Moderators note: please use your diligence when purchasing any items on the forum.
I have received a note that oem letters include part numbers on-the back.
mgreene
Here is the back of an original "N" - you can make out the part number on the back...
1966 GT-350H
1969 428SCJ Mach 1
1970 Boss 302
1972 Pantera
21.04
I had not heard of "Engineering numbers" appearing on the back side of the trunk/fender MUSTANG letters.  After reading the last two posts, I had to remove the same letter "N" from my original late 66 SJ Hi-po GT Conv to have a look.  It does have 4 small numbers that appear to be 5640 as said in the previous posts. (Photo attached). I have revised my ad and removed "Assembly line" from the description.
As an additional resource, I've posted a photo of a set of the same letter set Ford offered in dark blue and white boxes in the late 70's or early 80's era (not for sale).  We see there are no engineering numbers but are genuine Ford parts. Just wanted to display the follow up for any potential buyers to prove my parts listed are genuine Ford parts.  Good luck finding an earlier set.
TA Coupe
Cleaned up the picture of the first N.
      Roy
If it starts it's streetable.
Overkill is just enough.
mgreene
Quote from: 21.04 on September 25, 2025, 12:53:00 AMI had not heard of "Engineering numbers" appearing on the back side of the trunk/fender MUSTANG letters.  After reading the last two posts, I had to remove the same letter "N" from my original late 66 SJ Hi-po GT Conv to have a look.  It does have 4 small numbers that appear to be 5640 as said in the previous posts. (Photo attached). I have revised my ad and removed "Assembly line" from the description.
If you look closer on the left vertical portion of the "N" that you pictured you can make out the first part of the Ford part number which is "C5ZB" I believe.
1966 GT-350H
1969 428SCJ Mach 1
1970 Boss 302
1972 Pantera
