strut rod washer
Started by cob428, August 11, 2025, 06:38:15 PM
cob428
Is this the correct color for the strut rod washer on a 1969 Shelby GT 500
Pete
It depends, do you have a small or large type suspension?
cob428
Quote from: Coralsnake on August 11, 2025, 06:53:57 PMIt depends, do you have a small or large type suspension?
big suspension
Pete
correct its a blueish color because washer is thicker.
cob428
Is there color palette to use, light blue, medium blue? Paint or powder coat?
Pete
Quote from: cob428 on August 11, 2025, 09:08:40 PMIs there color palette to use, light blue, medium blue? Paint or powder coat?
Pete
I've seen/found them a couple of "related" colors. The ones I've seen most often on unrestored cars is more medium to slightly lighter strong blue while a teal color shows up also but I may be remembering 70 washers
Also paint. No US auto maker was using power coating on the cars at that time. Also powder coating will coat them too thick producing a "dipped in plastic" look
Here is an example of the blue from a late April Dearborn built 69 with big suspension. Color in the picture on my screen is fairly close to it in person.
cob428
Need some help, purchased the strut rod bushing kit from Dead nuts (pic #1) the zinc insert does not fit through the front washer (pic 2) what is the correct orientation pic 2 or pic 3. According to Osborn chassis manual it is supposed to insert through the washer. Don't know if that applies to Shelbys big suspension or not?
Pete
3 the washers always cup inward unlike some aftermarket.
cob428
Quote from: Special Ed on December 20, 2025, 10:44:28 AM3 the washers always cup inward unlike some aftermarket.
Ed, is the zinc sleeve suppose to go through the front washer, the pair I have dont do that?
Pete
The sleeves go thru both washers as they are different diameter like the washers then they slide together male female style.
