Source for Koni Rear Shock Absorber Mounting Nuts (4)
Started by SHELB66, July 11, 2025, 07:49:51 PM
That gauge is very handy to keep hanging in the shop particularly when I store buckets of used bolts unsorted.
Some of the SAE and Metric are very similaar. 5/16 nc v 8mm 1.25. You can almost substitute one for the other.
TA Coupe
If your guys were real men who actually worked on your cars, you would have a Tap and die set that would have a thread pitch. And count tool, that would be part of it. Mine does.
     Roy
If it starts it's streetable.
Overkill is just enough.
By the way home depot and loew's have that "special tool" to measure nuts and bolts
I usually walk in and fanagle with it until I determine if it is standard or a metric size
It's like renting it, but not really renting it.
Kool places them lowes and HD
S7MS427
Did anyone think of just measuring the OD of the thread to see what it is? That would help...
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
SHELB66
#20
Quote from: Bob Gaines on July 13, 2025, 04:13:11 PMThis is the gauge I have to help me identify nuts and bolts. I found some Koni hardware on a later used shock while digging through some parts today and this is what the gauge identified it as.
We have a match, Bob!  Thanks very much.  This size (M10x1.0) is readily available.  Thanks also to everyone else for chiming in.
Craig R.
PS:  KONI just emailed me confirming the size.
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
02 Explorer Sport Trac
Quote from: SHELB66 on July 14, 2025, 02:05:57 PM
Craig R.
Happy to hear you have found resolution
Great to go directly to the source KONI
