1966 Speedometer cable. (Found one)
Started by SFcarbuff, July 08, 2025, 06:28:08 PM
SFcarbuff
Does anyone know the correct cable length and correct cable housing length for a T-10 mid March built car?   Any recommendations on a reproduction cable if I can not find an original at this time?  Thanks for your time!
Correct OE cable (casing and core) for all 65-66 4-speed cars is Ford C5OZ-17260-A, total length according to the MPC is 64.92".
If you find a NOS one floating around check it first since it will likely be a later service part and in turn not look like and original if that is what your aiming for
SFcarbuff
Thank you both for the info. Helps alot.
I have a NOS Correct OE cable (casing and core) for all 65-66 4-speed cars,Ford C5OZ-17260-A, still in the clear ford bag if anyone else needs one.
