69 Taillight harness
Started by cob428, July 29, 2024, 09:33:58 AM
Dennis Y
Was that your original harness or a new one? Thanks, Dennis
cob428
In response #8 you can see my original harness at the top and after wrapping in the bottom.
Pete
Quote from: cob428 on April 09, 2026, 09:55:12 PMIn response #8 you can see my original harness at the top and after wrapping in the bottom.
Pete
It is hard to tell from the picture but did you use friction tape or vinyl stretchy electrical tape for the last part?
cob428
Friction tape, hope that was correct. I have both if need to switch to vinyl tape. It was friction on it before I sent it to have it wrapped.
Pete
Quote from: cob428 on April 10, 2026, 08:28:47 AMFriction tape, hope that was correct. I have both if need to switch to vinyl tape. It was friction on it before I sent it to have it wrapped.
Pete
Yes Friction tape is correct. Glad to hear it.
cob428
I do have a question about the wrap on the harness. When the harness was returned they also wrapped the fuel harness over to the plug. Should that be the case or should I remove it?
Pete
Quote from: cob428 on April 12, 2026, 11:01:31 AMI do have a question about the wrap on the harness. When the harness was returned they also wrapped the fuel harness over to the plug. Should that be the case or should I remove it?
Don't see your "plug" where the wrapped loom connects to the unwrapped wire that connects to the sending unit but here are some pictures of unrestored cars for you to compare and consider
Your tank sender wireing is done correctly DO NOT remove threading . 69 shelby (same as cougar) had 2 wires going to tank sender but only 1 gets used. Mustang uses 1 yellow wire but cougar had the low fuel warning  XR7 sender option  that uses 2 wires so both wires had to be threaded together but on shelby only 1 wire is used to plug into yellow sending unit wire.
