427 sideoiler short block C5AE-H
Started by Bigtphx, November 29, 2023, 10:57:30 AM
Bigtphx
427 side oiler short block, C5AE-H casting 5M17 date. Fresh build from Duffee Motorsports 11/7/23. Has .040 Race Tech custom pistons, reconditioned C6AE-E Lemans rods. Fresh C4AE crank. Block has 2 sleeves one older and 1 new one, block was maged, sonic checked, pressure tested, align honed, decked. Rotating assembly has been balanced. Pistons set up for 10.6 compression ratio with CJ heads or 72cc aluminum heads. Clevite rod/main bearings, ARP rod bolts, Durabond cam bearings.
This is a factory solid lifter motor, never drilled for hydraulic lifters. No cam included. 427 with 4.270 bore, 433 cu in.
Have sonic test worksheet and piston spec sheet available.
Great motor for Cobra, or?
Price is $9500 cash!! No trades! No scammers!
Local pick up only. Shipping on buyers dime.
Have a manual flywheel that's been turned available
$250.
C6AE-R heads $400 pr
Pair of adjustable rockers $350
NOTE:flywheel, heads and rockers not sold separately until block sells
428kid
Interested in the rockers could i get some pictures please? You may email them or text  them, Forrestsraiders@yahoo.com or 931 three one nine 0685, Thanks Lance.
