Front end assembly diagram or schematic for nose, headlight brackets, grilles?
Started by BeaterGT500, October 15, 2023, 01:24:56 AM
BeaterGT500
Now that my car is running and stopping, I need to install the front clip.  Is there any assembly diagram or schematic showing how to install the 67 Shelby nose, headlight buckets (inboard), grilles and support brackets?  I could likely figure it out but having a guide would be great.  I hear it's a ton of fun to get the fiberglass nose on, but getting all the lights and brackets on and working is where I am now.
WT6066-2600
I have some electronic copies of illustrations like this one.  If you want copies, PM me with your email and will forward what I can, good luck
"#1 fan of theCoralsnake.com"
There were many variations thought-out the production run, your car/parts may not look quite like some of these examples.  would help to know the car number or which high-beam light location you have, Inboards or Outboards.  OK, I see you have car #683 Guessing you have inboards and the two-piece grill, and you probably have the "Flat-Plate" mounting brackets at all four headlights.  (if you need the rubber grommets that go in the back of the headlight buckets I have them, also the lower grille, bottom edge protective strip))
See reply #8 on this thread regarding this topic, hope this helps...
https://www.saacforum.com/index.php?topic=10148.0
Some more that might have some helpful info...
https://www.saacforum.com/index.php?topic=3152.msg27847#msg27847
https://www.saacforum.com/index.php?topic=6204.msg53308#msg53308
BeaterGT500
Thanks all for the quick assist as usual!  I have the AMK kit so I should be in good shape.
