Correct fuel linkage for 1968 Gt500, Nov 67 build date
Started by 1968GT500CS, May 07, 2023, 01:58:08 PM
1968GT500CS
Hello
Any assistance with springs, clips, etc for correct attachment to carburetor.  Any help, pictures?
Thanks in advance
Well that is a Holley, but not the correct one. This is what the original set up looked like
Quote from: 1968GT500CS on May 07, 2023, 06:07:42 PM
9510-U
That is a 69/70 universal carburetor for automatic which is designed for a different type throttle control and also a different automatic kick down rod. It obviously can be made to work but not the right carb from the factory.
TA Coupe
Since he has only been around for less than a month maybe someone can post what the correct carb is.
       Roy
If it starts it's streetable.
Overkill is just enough.
Quote from: TA Coupe on May 07, 2023, 08:30:42 PM
       Roy
Reply #3 shows the correct carb. It is marked C8ZX 9510 A regardless of it auto or standard.
Mr Gaines is correct.
The Autolite carburetor was also used.
C8AF-9510-AE
Quote from: Coralsnake on May 08, 2023, 06:58:46 AM
C8AF-9510-AE
Just to add clarification, the Autolite carburetors that Coralsnake found that were used was on very early production GT500's.
Quote from: Bob Gaines on May 08, 2023, 11:06:12 AM
Mid Jan-early Feb 68
