1966 Headlight question
Started by SFcarbuff, November 14, 2022, 06:19:08 PM
SFcarbuff
I have a Mid March Ford built 66.  I have one headlight that is embossed where you feel the FOMOCO script and one that looks etched and can not feel.  Which one is correct, if any?   Thanks
Quote from: SFcarbuff on November 14, 2022, 06:19:08 PM
Westinghouse (embossed) was not a typical supplier to the SJ plant as I have not observed or heard of any of my peers observe the embossed bulb on a 66 GT350. GE and TS were the typical suppliers to the SJ plant 65-67. Both bulbs had the FOMOCO etched into the glass although the trademark artwork was slightly different depending on the MFG.
SFcarbuff
The way I understand it, correct me if I am wrong.
1965 - GE with stamped on the back "Made For Ford" (no etching on the outside of the bulb).
1966 - Tung-Sol: TS wide flute with the etching "Made for Ford" on the outside of the bulb.  I think this is correct for other years too, but I know the size of the bulb is smaller in other years and I don't know for sure if that is still correct for those bulbs.
Quote from: silverton_ford on November 14, 2022, 09:21:19 PM
1966 - Tungsten - TS wide flute with the etching "Made for Ford" on the outside of the bulb.  I think this is correct for other years too, but I know the size of the bulb is smaller in other years and I don't know for sure if that is still correct for those bulbs.
No etching before approximately March 65. After that they were etched with the trademark on the face of the bulb. Both GE and TS were used as it pertains to SJ Shelby's 1965-67.
To add to this post and elaborate a little more....this is what I have been told and obviously, there are always exceptions to the rule.
Part number 6012 was used by both General Electric(GE) and Tung-Sol(TS).  This bulb is the wide flute lens.  In the late 60's it was superseded by part number 6014 with a narrow flute due to government requirements for some sort of regulation on the width of the light beam.
To add clarity to my post above the GE bulbs were stamped "Made for Ford" on the back with ink, no stencil on the front.   1966 the TS had both "Fomoco and Made For Ford" etched on the lens of the bulb in the center.
This is probably splitting hairs and could be a matter of opinion and personal findings and documentation of original cars.  I have been told the GE bulbs were early 1965 through approximately April 1965(I know Bob you said March...I don't doubt that at all.).  During late 1965 and early 1966 they used both GE and TS bulbs and were all TS bulbs by October(+/-) of 1965 for the rest of 1966 year and continuing on.  The embossed or "cats eye" cast in Ford logo bulb wasn't used until the 70's.
Another thing to mention is the bulbs had a date code cast in the lens of the bulb.
Also to note just for fun knowledge, Tung-sol was bought out by Wagner on August 19, 1966 and became Wagner/Tung-Sol for a while and then later just Wagner.  After the companies merged, Wagner expanded their brand and basically took over the market making bulbs for all major auto manufacturers.
Of course, there are always exceptions to the rule, this is just what I have been taught and I thought it might be helpful to share.  I do not intend to take anything away from the post, just wanted to add a few things to help further the discussion.  Please don't take my post the wrong way.  Thank you.  :)  I hope this helps.
Have found TS on earlier (and spring of 66) but of course we don't know if they were replaced early in their life or we just need more early examples  :)
Some pictures to illustrate some of the comments already posted and to expand a little. Originally posted in thread on CMF
Pic 1- Original GE headlight from a fall 65 SJ example (pics #1-3)
Pic 2-  The cast in details on the lens
Pic 3-  And the MADE FOR FORD on the backside
Pic 4-  From a 66 SJ built Mustang (5R1380xx) a TS example with MADE FOR FORD  over the FoMoCo on lens
Pic 5- From an earlier post here on this site from a possible April 66 built car with the MADE FOR FORD also
mickmate
Are the etched type available or is it only the embossed style from CJ and Branda?
Not sure where these might fit in the mix, they are the smaller size like for a '67.  Tung-sol in the words molde in the front lens and the FoMoCo etched.
Quote from: mickmate on April 02, 2025, 11:24:24 AMAre the etched type available or is it only the embossed style from CJ and Branda?
The ones CJ or Branda sells are not correct in a variety of ways. Not the least of which they are the wrong OEM mfg for Mustang/Shelby. Short of finding rare used working or NOS bulbs there is a way to get what you need. NPD sells a exact stencil one specific for GE and the other for Tung-Sol .You sand etch it on the bulb yourself. You need to source a GE or Tung Sol donor bulb. Tung Sol is no more but GE still makes headlight bulbs . A non halogen bulb is a must. The non halogen GE bulbs are getting hard to find and typically have to be sourced on the secondary market. There is also a issue of the flute design on the glass however it is a non issue IMO in everything other then Thoroughbred/DIV I concours. GE and Tung Sol  were the two mfg's bulbs typically used on the Shelby's 65-70 not because they were Shelby specific but because they were the ones used at the plants building Mustangs. The molded/embossed FOMOCO was only used on Westinghouse bulbs now known as Wagner. The Westinghouse bulbs were typically used at other Ford assembly plants for other body style cars
trotrof1
I obtained a pair of TS etched bulbs from a ex fire department Econoline van. Even trade for a pair of new halogens installed. Maybe you could source from one of those southwestern salvage yards.
Quote from: trotrof1 on April 02, 2025, 01:17:55 PMI obtained a pair of TS etched bulbs from a ex fire department Econoline van. Even trade for a pair of new halogens installed. Maybe you could source from one of those southwestern salvage yards.
In years past we always searched and checked postal vehicles since they rarely used their headlight and were more often still good. Of course over the years every idiot spent their time in yards breaking headlights as a pass time apparently  ::)
School buses also
