1967 GT500 which engine would you put in and why?
Started by Kent, October 17, 2022, 04:39:33 PM
Quote from: Kent on October 19, 2022, 02:19:31 PM
Quote from: 98SVT - was 06GT on October 19, 2022, 01:16:08 PM
At the far end if he wants to carve up some twisty roads and play at track day then an all aluminum FE with 500+ hp is the way to go. Since it lacks the original engine already a Shelby FE dressed as a 67 may be acceptable and add some value at sale time. https://www.shelbyengines.com/collections/shelby-fe-engines
That's what I thought build a shelby fe but with original intake, carbs, ignition etc. should really look awesome and it should make a lot of fun. But then I don't know if the 9" with just 31 spline will survive this. Its really a tough decision to make.
The 9" will be fine you can't get enough tire in the stock wheel well to get enough traction to break it.
427heaven
Kent-   It really is not that difficult of a question to ask yourself. Most SHELBYS dont have their born with engines so would you like to drive something that sounds like your vacuum cleaner when driving it or would you prefer the wail of a highly tuned Big Block echoing off the buildings or canyon walls, I compare it to wanting a Cobra..... A small block 289 is fun- But a 427 SC is breathtaking, I would choose the latter. Here is a picture of mine with a 427 medium riser, 99 percent of people dont know the difference or really care, but what they do like, is going for a ride and screaming like a girl SLOW DOWN/SLOW DOWN!
Considering the fact that there is a limit to how much power you can actually put on the ground in a "Mustang chassis", astronomical numbers seem to be somewhat of a lip service to me?
IF we are talking around stock CI displacements, then a reworked 428 PI is not so much out of the question.
Essentially the basis for a 427 top end is already there. Certainly there is virtually no difference in torque output.
The criticism of the PI is in the under camming of it and the inherent weakness of the stock connecting rods.
I'm getting 500hp out of my 347. If you can't get that out of a 428 then you must be hanging out with the daily riders of the short bus?
Put some good valves, springs and cam in the top end. Put a set of Hooker headers in it and leave it dressed as a '67 GT500 should be.
It is quite a handful to deal with at that.
If you want to play virtual HP games and why would you? You can play that with Fantasy Football amongst other things.
Put the money into the internal performance parts that you don't see. The thing is plenty fast and lethal that way. Let the guys with the aluminum everything and the titanium gonads show their cars at the local shows and impress the crap out of the kiddies while you drive your 500.
Quote from: shelbydoug on October 20, 2022, 09:27:54 AM
+ 1 all that power being transferred through the  antique drive train and chassis creates havoc on all parts.
Broke a brand new motor mount, that triggered a broken fan shroud, that bent a fan and warped the fan clutch. Out back made one tire lumpy and the other shredded into pieces.  About $2K in parts and repairs, just is not worth it.
Start it, let it kackle and go for a nice cruise, enjoy your day
427hunter
500 horse out of a 347 - what heads, cam, compression, intake and exhaust are you running?
Inigo Montoya
Jackie Brown
crossboss
IF it was mine, I would keep it an FE of course. So, in would go a nice stroker 428. Alum heads, CJ exhausts, Tunnel Wedge intake , hyd roller cam, etc.
Past
1968 GT-350
1970 GT-500 #3129 Grabber Orange
Current
1969 Mustang Fastback FOX chassis 5 speed 4 wheel discs Can-Am 494 Kaase heads intake with 1425 cfm Autolite Inline carb Trans-Am style
1970 AMX 5 speed 4 wheel discs
1965 Volvo P1800  CA black and gold plates
1993 Grand Prix LQ-1 3.4 DOHC
Quote from: 427hunter on October 20, 2022, 10:27:09 AM
Ah! How much you wanna' pay?
427hunter
Quote from: shelbydoug on October 20, 2022, 11:31:17 AM
You still haven't answered the question.
Inigo Montoya
Jackie Brown
Quote from: 427hunter on October 20, 2022, 10:27:09 AM500 horse out of a 347 - what heads, cam, compression, intake and exhaust are you running?
Big HP in todays engines is almost too easy. https://www.shelbyengines.com/collections/shelby-289-engines/products/aluminum-289-364ci-stage-i-500hp
Paint it blue and no one will know.
My 310" Cleveland cranks out 650 @ 7,800 it was built in 85 with all the best parts and is alive and well today..
Carrillo rods
SVO A3 aluminum heads
Roller rockers – Crower stainless
Moroso Stud Girdle
Steel billet crank
Olson dry sump pan
Titanium valve keepers
Pistons – Venolia
Motorsport 351 pillow NASCAR block
Steel billet crank
427hunter
Quote from: 98SVT - was 06GT on October 20, 2022, 01:35:53 PM
Carrillo rods
Moroso Stud Girdle
Steel billet crank
Olson dry sump pan
Pistons – Venolia
Steel billet crank
Bench racing lives on  ;D - Everyone is cruising around at 7,800 rpm in their 1000 hp mustang - on radial tires and doing 10 second passes...
Inigo Montoya
Jackie Brown
Quote from: 427hunter on October 20, 2022, 01:49:21 PM
Carrillo rods
Moroso Stud Girdle
Steel billet crank
Olson dry sump pan
Pistons – Venolia
Steel billet crank
Love it !
Both our 69s are solid high 13 second to 14 second travesties......lmao
Now the late models are another story
Sorry should have included a picture
crossboss
Quote from: 98SVT - was 06GT on October 20, 2022, 03:28:58 PM
I believe that 427hunter was referring to the claim that a 347 made 500 HP...not a 'race car'.
Past
1968 GT-350
Current
427hunter
Quote from: crossboss on October 20, 2022, 03:44:37 PM
Scott, why do I feel like we went back in time and are standing in the Super Shops parking lot.
Inigo Montoya
Jackie Brown
