Connecting rods part number for GT500?
Started by Kyle, July 30, 2022, 02:44:35 PM
Kyle
Hi All,
What are the correct Assembly Line part number on the connecting rods for early 67 Shelby GT500 please?
Kent
From my knowledge and what I have seen in the years C6AE-D with the 19/32 nut.
Kyle
I am seeing that there are C6AE-C and C7AE-B as well.
I never saw C6AE-D?
The ones I have taken apart had C7AE-B rods with big bolts like any 428 would have. Same basic rod as a 390, just has the bigger bolts.
Kyle
Quote from: Royce Peterson on July 31, 2022, 12:34:06 PM
On early 428's you found C7AE-B please?
C6AE-C engineering number cast into the rods.
It's got the small bolts and really is just a 390 rod.
If you are rebuilding use a better aftermarket rod.
The C7AE-B is a service substitute. I had one set where they were mixed.
Quote from: Kyle on July 31, 2022, 02:42:22 PM
On '67 Shelby 428's. 1966 428's I have had a couple blocks that were stripped before I bought them so no idea there.
Kyle
Still not shure what were they from factory?
C6AE-C or C7AE-B on a 428 cast date 1966 September?
Quote from: Kyle on October 09, 2022, 02:53:50 PM
It could be either depending on the build date. C7's probably don't start showing up until April or May of '67 but no one that I know of has attempted to document that.
The most significant weak spot in the engine is the connecting rod. Some think that 652cfm carbs v 715's were done because of the bad rods and to "keep them from coming through the side of the block".
No one starting from a scratch build is going to use the stock rods.
TA Coupe
What did the carbs have to do with them blowing up?
         Roy
If it starts it's streetable.
Overkill is just enough.
Based on my records and the examples I've documented - C6AE-C
430dragpack
Quote from: J_Speegle on October 09, 2022, 07:06:01 PM
Do you have notes on large rod bolts or small?
Quote from: TA Coupe on October 09, 2022, 05:36:20 PM
         Roy
Just something that Randy said to me about limiting the potential rpm of the engines by limiting the carb capacity. I had never thought about it in that way before.
The quote is something like, "to keep the rods from sticking through the block, they limited the size of the carbs".  ;)
Kyle
Thanks a lot.
Kyle
Quote from: 430dragpack on October 09, 2022, 09:36:47 PM
I have the same question ?
