66 San Jose ball joint plug nut color?
Started by hertz350, December 30, 2021, 05:32:20 PM
hertz350
What finish are the plugs for the upper and lower ball joints that came in the zerk fitting holes from the factory?
Quote from: hertz350 on December 30, 2021, 05:32:20 PM
Bare steel.
rraceme
what protective coating is used to keep parts which have a bare steel finish from rusting? a flat and satin clear coat?
SFM 6S2227
68stangcjfb
Sorry to hijack thread but does bare steel apply to '68 Daerborn and Metuchen?
68 1/2 CJ Mustang GT FB auto 3.91s 68 1/2 CJ Torino GT FB 3.91s 60 T Bird 64 Falcon Sprint conv. 4Spd 65 Falcon Sedan Delivery 67 Fairlane 500 SW 428 4Spd, 68 Torino 4dr 95 T Bird SC. 89 F250 2wd, 98 Mustang GT conv. 99 Jeep Cherokee 2002 T Bird. 96 Harley FLSTN Heritage Special 05 Yamaha V Max
greekz
I have used Boe-Shield on bare metal parts.  It coats them well, but requires maintenance. If your control arm ends are bare steel as assembly line, you can coat the ends, which will automatically cover the plugs.  You can use a flat clear coat that will last for a while depending on your driving habits, i.e. driving in the rain.
SFM 6S1134  '67 GT-350 #2339
Quote from: rraceme on December 30, 2021, 07:14:30 PM
Oiled if anything originally. Today a protective oil would be suggested. Clear coat will not hold up any longer than the oils we use today, it will crack, yellow or allow for moisture to enter at the treads and creep under the clear creating rust
Boeshield is often the product of choice since its affordablp and widely available
Quote from: 68stangcjfb on December 30, 2021, 08:07:52 PM
Yes
68stangcjfb
