Correct Paint Color Undercarriage 1969 Shelby
Started by Frankdenver, November 19, 2021, 07:44:14 AM
Frankdenver
What is the correct paint color of undercarriage of 1969 Shelby GT350? Is it same as 69 Mach I or is it the red primer finish? Thanks.
Depends on when car was built early cars were orange primer then batch paint started showing up. Just look in transmission tunnel area as thats the best area that should still be original paint yet.
Harris Speedster
The 69 Claude DuBoius> ? sp, 69 gt 350 Conv, had a med grey primer color.
Sold it to C Brown, I do not know if Chris changed the under body color or not.
That is the color that I found in many area's of the car.
It was the Maroon car Ed.
Respectfully,
John
Quote from: Frankdenver on November 19, 2021, 07:44:14 AM
My GT350 vert May 6th build: Notice clogged sprayer and dark charcoal is the mix that came out on my car that day.
Second-4th  pic April Boss 429 original paint survivor. Seraphim's car, Ed.
427hunter
My 69 gt500 (602) was built in January, it was slop gray.
Inigo Montoya
Jackie Brown
Harris Speedster
That is the color guys.
Slop grey>> that is a good description>> ha
I wonder if the color of the car determined the color of the primer sealer?
The maroon car >> should have had red oxide if that was the case ?
John
Depends on when your car was started at the plant.
Best place to figure this out is your cars original finishes so look unless you or someone else has already removed the original paint in this restoration or another. There were a number of documented periods through the year where the plant reverted to a red oxide epoxy primer similar to what was used from the firewall forward on the front frame rails and firewall forward section
Now lacking any original evidence then you should look to other cars finished the same week or day as your car - identified through a Marti report
This article in this thread may help and provide some additional information also
https://www.saacforum.com/index.php?topic=929.msg6979#msg6979
Frankdenver
Thank you for all the replies. My car was repainted before I purchased it. It has an order date of 3/12/69, and release date of 4/2/69. Unit number 481925, Hertz car. Appreciate any additional information.
Harris Speedster
Jeff,
The 69 Vert Chris bought from me was sent to Claude >> in Belgium>> Carrolls importer.
I brought it back to Georgia port in US.
it was like # 750 or maybe # 1450 ? both are just guesses, registry will show though.
One thing that was real weird, it had a serial number stamp on back of the head, not block, and was actually 2 numbers off on last digit, go figure.
It was the born with engine.
All is to the best of my recollection. Decades ago !!!
John
Dan353
My 69 GT350 was built January 6 1969.  It has the gray paint on the underside
          Dan
Quote from: Dan353 on November 19, 2021, 07:48:52 PM
Dan can you describe the gray? Have a few others a week or so from your date and wanted to compare
427hunter
Quote from: J_Speegle on November 19, 2021, 09:04:18 PM
It was all the leftover paint mixed together which came out various shades of gray. My car was unrestored when I bought it and the undercarriage was graphite gray, I've seen lighter and darker when I was doing research.
Inigo Montoya
Jackie Brown
Quote from: 427hunter on November 20, 2021, 12:13:23 AM
Understand and thanks for trying to help. Have a fair amount of pictures and floor samples cut from floors all with (well most) with VINs. Was interested in what the Dan found on his specific car since we find trends and patterns in the findings once graphed and compared.
Fixed the link in the other thread I posted a link to above. Not sure what happened byt works now
Quote from: Frankdenver on November 19, 2021, 06:02:02 PM
Thanks that really helps narrow it down and your in luck since I have records of another 69 GT350 Hertz big suspension completed on the same day.
On that example we found the typical red oxide epoxy (not the flat Rustoleum look) applied on the bottom of the front frame rails from the firewall forward. From approx the firewall rearward a medium dark gray with a blue tint to it. Have other examples built a few days later where we find a change in the color and look but don't want to get off or focus - your car.
For that car we reproduced the color using a early 2000's VW exterior color with some blue added.  Was really happy with the color and look
From a picture I already had in storage on line where are just some of the examples of the blueish tinted grays we find on 69 Dearborn built cars. These are only single examples and the finished could differ a bit based on what the majority of exterior colors they used the day or days before.
Now the color you see on your monitor is likely different from what the color was originally due to digital camera settings, monitor settings and so on but it might give you a general idea. Closest for comparison to what we found is in the lower left corner below
Dan353
Jeff,  I will try to post a picture of the paint this coming week I have a spot that the where the factory sealer came off by the threaded plate for the seat belt harness
     Dan
