1969 500 Electrical question
Started by corbins, August 07, 2021, 11:35:52 AM
corbins
Maybe stupid .... no problem , Is there any way or procedure for "bench testing" the console wiring prior to install ?
Thanks !
Quote from: corbins on August 07, 2021, 11:35:52 AM
Thanks !
While I didn't watch this video through it is about continuity. I'm running into a problem right now-no power from my steering wheel horn connectors to my horns in my Mach1(actually none at my wheel blinker switch). Anyways when I had all my wiring out of my Vert over 20 years ago I tested it out to make sure I had continuity from one end to the other. All my wiring came out with no issues when installed back in the car. Hope this gets you going. Gary
https://www.youtube.com/watch?v=R6DgIA_ikQQ
Thanks !
I know a previous Shelby owner Chris Kuchem that wired up a way to bench test all of the wiring in his car . Wiring was laid out and mounted to sheets of plywood with switches etc.. It was very well done but so elaborate and took up most of his basement. The time it took to make it he could have literally built his entire car.  All the ways that I can think of would result in much more time then just plugging the harness in with out installing the console insert down permanent . Of course you would have already unwrapped harness to inspect and repair damage ,tested for continuity on each wire and taken the appropriate precautions to disconnect power immediately in the case of a problem.
69 GT350 Vert
If you are using a reproduction console gauge harness, make sure the terminals that attach to the gauges are triangulated on the ends.  Otherwise, they can contact the gauge cup and short circuit.  The originals are triangulated in the photos.  The reproduction was not as I learned the hard way.
corbins
Thanks everyone !!  I will defiantly check those terminal ends ! Guess a continuity check is the best we can do. Hate picking up on someone else's work. Discovered the terminals in the fuse box were rusted to the point of breaking. Spent 4 hours correcting that.... and I hate electrical stuff anyway :)
