1968 console removal
Started by calspcl, May 12, 2021, 12:06:07 AM
calspcl
My wood trim is peeling on my console. Any tricks suggestions on removal and replace would be appreciated.
1968 GT350 #1198
I'd be inclined to remove and disassemble the console to detach the center plate from the sides.  Use a heat gun to get the old decal off, clean off the old glue with solvent and install a new wood grain insert.
calspcl
I have the wood grain replacement, great idea remove old wood woodgrain with heat gun.
Where are the attachment screws on the console? Any precautions ....
thx!
1968 GT350 #1198
It's all self-explanatory once the console is out and you see how it's assembled, nothing complicated.  Be a good opportunity to address any other issues or improvements needed while it's out.
TedS
Quote from: calspcl on May 12, 2021, 12:22:18 AM
thx!
To remove the console from the car there are 2 screws in the bottom of the compartment under the arm rest. I have an automatic so I remove the shifter tee-handle and bezel and move the shifter to "1" position (to the rear). Console should slide back so you can disconnect gauges and wire to the light in the rear seat area. Never done a 4-speed but I would expect it to be similar.
Ted
Corey Bowcutt
I would definitely remove the seats to aide in the console removal.  Along with the 2 screws in the compartment there is also a 90 degree bracket under the dash on the passenger side that needs to be removed.  It really helps to feed the oil pressure wire and the amp meter wires thru the firewall a bit to give more freedom of movement of the console as you gain access to disconnect those gages.
Corey
Mike Shally
Be careful the metal is thin and bend easily; I added an additional support to the back side to help it maintain it's original shape.
original owner, 68 Shelby judge, MCA Gold Card Judge, MCACN Shelby Judge
Poor Ron
When removing the console on a 1968; be CERTAIN to unhook the battery first.
calspcl
1968 GT350 #1198
corbins
AS noted ...disconnect battery first. Passenger seat removal is a help. DONT mix up alt wires when re-installing. And after applying new woodgrain, use the heat gun from the bottom lightly to set the adhesive, it is not very good . Don try any spray on additional adhesives, it will make it lumpy , trust me :( .   Good luck !
Beeler422
I realize this is an old thread but I'm going to be doing this.  Is there anywhere to buy a new metal piece or do I need to fabricate one?  Thanks.
You will need to have one made.
Also remember the 4spd and auto pans are different
Quote from: Beeler422 on August 15, 2023, 07:17:08 AM
I think I have an automatic one
Beeler422
Oh so close! I need a 4 speed. Thanks though!
Beeler422
Any idea what gauge the metal is?
