67 GT350 Automatic May 67 Ford Shelby June 67 correct Carb?
Started by 64cobra, December 13, 2020, 02:55:08 PM
64cobra
Curious what date code would be appropriate?    Would a 2nd week may be too late?
'67 289 HiPo's used in that year Shelby's had the carb installed at the Cleveland (Ohio) engine plant - so the carb date needs to be earlier than the engine assembly date that is stamped on the front-left upper part of the block - edit - see attached.
In short because of the above sequence, yes unlikely that a mid-May date could be correct (too late).  Might be better to consider late Feb., March or early April for carb date code.
(Also there were two carbs seen on cars, another issue.  Typically a 715 Holley but some got a Autolite)
Edit as per Dave M Reply #8 below
64cobra
One example from the same production period (June) as your car had a Feb 67 date for the carb
Quote from: 64cobra on December 13, 2020, 06:37:03 PM
Willing to pay for right date code
Might consider placing a wanted ad with the details in the section for that. Might find one that way
greekz
My car, #2339, GT-350, automatic was completed at San Jose May 3.  It has a Holley 715 with a 731 date code.  I believe #2340,
a GT-350, automatic has the same date code.
Greek
SFM 6S1134
'67 GT-350 #2339
'65 Fairlane Station Wagon
2002 T-Bird (since new)
'25 Explorer ST
oldcanuck
Weren't automatics typically built with Autolite carbs ?
Bob
Philadelphia, TN
GT350DAVE
They were built with Autolite carbs in 1966 but in 1967 the 715's were used. Some say a few Autolites were also used but so far we haven't seen one.
Support the SAAC Registry
Mojie21
Sorry to hijack this thread, but do the manual carbs follow the same date pattern? For example, a May/June built 4 speed car would have a February/March dated carb?
GT350DAVE
My Late April and early May cars both have March carbs.
