4159 KR resto commences
Started by Jack4159, November 10, 2020, 10:05:25 AM
Jack4159
Thought I would share. Started stripping 4 days ago and have had a good run, should be done tomorrow. Body going off to the experts who need it for 6 months, rotisserie, going back to original highland green. In that time me and a mate helping will work on everything else. Got a nice surprise with the body, a little minor rust in the cowl, A pillars and trunk recess that will require patching but very minor and nothing anywhere else! All original panels, no patches anywhere. Even found the build sheet !
Well done. You can do a little more, by looking for writing on the radiator support and cross member
Look where front fenders bolt to radiator support on both sides (Two vertical holes) and along bottom front cross member.
Jack4159
Thanks Pete, I'll check it out tomorrow, nearly midnight here now so well and truly knocked off.
You can also look on the front face of the passenger side shock tower for letters or numbers
Bigfoot
RIP KIWI
RIP KIWI
68krrrr
Very cool & good luck where did you find your build sheets & are you gonna keep the trailer hitch  ;D
Current
1967 GT500 #1724
Nightmist Blue /Parchment
2005 Ford Gt Midnight blue
1934 Ford Chopped & channeled
Previously owned
1968 GT/CS
"Fly low & avoid the radar"
Thanks Adam
Jack4159
Quote from: Coralsnake on November 10, 2020, 10:26:22 AM
Think I found some markings, passenger side looks like an R, can't make out the driver's side very well.
Couldn't find anything on the front crossmember or shock towers but managed to avoid some harder work by trying.  :)
Do the markings have any meaning?
Jack4159
Quote from: 68krrrr on November 10, 2020, 10:06:11 PM
Build sheet was under the dash wrapped to the main wiring harness with black tape, which thankfully had no "stick" left in it. Came apart no problem but very fragile.
Yeah the towbar is not making a comeback. The second owner had the car 40 years and the KR was his driver which he used to tow his racer, a GT350.
Sure they mean something 😉
The "R" is likely the engine code, but could be paint code.
The "78" is a rotation number
Quote from: Jack4159 on November 11, 2020, 07:59:13 AM
Quote from: TLea on November 10, 2020, 08:38:10 PM
I'm guessing 4 spd AC car?
Yep, good guess  :)
Not that much of stretch. 4154/4155 same  Figured they were in same DSO as yours
