Attachment Fasteners for Cobra T-Pan
Started by hertz350, November 06, 2020, 07:11:01 PM
hertz350
AMK uses out hex bolts in its master engine kit for the 1966 Shelby for the Cobra oil pan. I noticed "witness" marks on my T-pan indicating star washers were previously used. I have only seen those washers used with Phillips head machine screws.
So what are the correct fasteners that Shelby used in mid-March 'for the T-Pan?
Thank you.
GT350Lad
RBW bolts with star washers is correct. Virginia clsssic or Shelby parts and resto sells them as a kit. My car however has Rockford Pan bolts
Cheers
5S274
6S373
6S1276
Karguy
Hey Mate, haven't heard from you in a while, welcome back Trent!
GT350Lad
Quote from: Karguy on November 06, 2020, 10:09:38 PM
Thanks mate. Too much working. The challenge of the work and life balance
Cheers
5S274
6S373
6S1276
External tooth star washers is correct. You should see "bite marks" from the washers on the pan. I am 99.9 % positive there wasn't a manufacturer call out on these bolts OR header bolts. There was NO reason. 10,000 grade 5 1/4-20 x1" bolts "could be " from more than one supplier especially if "a couple thousand" were in stock and the rest were ordered or "staged delivery". Again SAI-Buddy Bar-Cyclone etc did not function like FoMoCo. where each bolt had it's own spec and blueprint!
We are discussing a 66 fastener subject but just so that there is no confusion it was the 65 GT350's that had the T pan changed out at SA before they got Ford to do it that typically used the Phillips head machine thread screw and star lock washers.Just a note for the memory banks.
